Split Horizontal and Vertical Alignments into Two Separate Alignments in ORD 2021R2
How to Split Horizontal and Vertical Alignments into Two Separate Alignments with maintain corridor?
  • If I understand correctly you want to split the alignments (horizonal and vertical) that are referenced by a single corridor. If that is the case, I think you will need to separate your corridor as well. How I would go about the actual splitting of the alignments is probably very dependent on how they were generated. I would probably duplicate the alignment file and trim the horizontal. In the vertical I would probably drop the profile, delete the unneeded portions and re-complex/set active. From there I would likely export and reimport those to have clean files/content. For the corridors, depending on complexity, I would again duplicate that file and use the Corridor Reattach command to link the two new corridors back to the respective geometry.
    Steve
    Steven Litzau, P.E. - Senior Consultant
    www.envisioncad.com
    ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33
    Power GEOPAK / Power InRoads - 08.11.09.918
    Civil 3D - 2021 / 2022
    Answer Verified By: lalit chandra
Reply Children
