Adding in Key Stations Causes More Model Inconsistencies
Hi All,
Has anybody noticed that when adding in Key Stations to fix model irregularities that the immediate area is typically fixed but it then causes more irregulates upstream and downstream of where you placed that Key Station? In other words, prior to placing a Key Station, Upstream and Downstream of that location where spot on, but after placing that key station the model "ripples" upstream and downstream, which takes more key stations to fix, and the process continues.
I feel a bit like I am chasing my tail here. Any thoughts?
