Does anyone know why corridor model switches don't work as intended in ORD?
In my template, I have a null point that has a horizontal feature constraint. When this horizontal feature constraint activates, the end condition I want modeled only models in certain locations. Key stations don't really help solve the modeling issue either. I've double checked that I'm using the correct Feature Name, the range of the Horizontal Feature Constraint is sufficient, etc. Running out of ideas why this isn't working.
GPK V8i (SS10) v08.11.09.918 never gave me any issues with template switches.
Thoughts or suggestions?
A workaround I discovered is using Parametric Constraints to control the null point being used as a switch. Also, I found that some spots the end condition wasn't solving since it couldn't find the terrain model so that may have been causing some issues as well.
Zach McCormick, EITSenior Transportation Design Engineer
Microstation V8i SS10 (08.11.09.919)PowerGEOPAK V8i SS10 (08.11.09.918)OpenRoads Designer CE 2021 R2 (10.10.20.78)
