Here is a picture of the problem..
I would like to customize it to where it expands instead of having it show a scroll up and down arrow..
to where it looks normally like this
Anyone ever had this problem before? it usually does that after awhile..while using the software
I may try to cleanup the files, *.xml or upf in the user preference folder "C:\Users\<<user login>>\AppData\Local\Bentley\OpenRoadsDesigner\10.0.0_1\prefs\" to restore the interface.
jing jing (o'.'o)
Answer Verified By: Christina Go
An easy way to open the prefs folder is to type the $ % explorer $(_USTN_HOMEPREFS) into the key-in tool in OpenRoads:
communities.bentley.com/.../how-to-reset-user-preferences-and-delete-microstation-s-temporary-files
You may also try resetting OpenRoads to default (see the Option 2 in the following article):
communities.bentley.com/.../restore-microstation-to-factory-defaults
Thank you! Was able to access and edit the pref folder. Hopefully it resolves the problem.
