I'm trying to assign a super elevation to a corridor, but nothing happens. I begin by referencing the SE file into the corridor(active file), select the assign super elevation tool, select the SE then the corridor and reset to complete. The box pops up and I fill out/verify the points and stations are correct, then I select "ok". After selecting "ok" the assign super tool starts over without placing the SE. I have a total of 6 models, 3 of which I have been able to successfully place SE and 3 I haven't. Any ideas?
I may check the "Point Control" by using Corridor Objects to see whether the Superelevation is set as correct point and reference point.
jing jing (o'.'o)
Jing Jing,
The assign super elevation tool will not assign the SE/point control, so nothing shows up in the corridor objects. I have a total on 6 corridors, 3 of which I have been able to apply SE and 3 that are not accepting SE. I'm not doing anything different between the corridors, so I'm unsure as to why I can't apply the SE to the corridors.
how do i export the superelevation?
you do a report,
when i do a report, it only lets me export as an .xml but to import i need a .csv. where do i get a .csv?
I have a sample xlsx here. You can export sheet 1 as csv for trying import.import_super_template.xlsx
how do i get something like this for my project?
Are you using the report browser? It has the ability to convert certain XML files to HTML or to TXT. And when a report is displayed, a right click in the report window will offer a menu containing export or display as other formats. Some steps even offer some options as part of the process.
And, it uses XSL Transformation (XSLT) language to accomplish this, which means that they are very customizable, if you know or learn XSLT syntax.
