I'm trying to assign a super elevation to a corridor, but nothing happens. I begin by referencing the SE file into the corridor(active file), select the assign super elevation tool, select the SE then the corridor and reset to complete. The box pops up and I fill out/verify the points and stations are correct, then I select "ok". After selecting "ok" the assign super tool starts over without placing the SE. I have a total of 6 models, 3 of which I have been able to successfully place SE and 3 I haven't. Any ideas?
when i do a report, it only lets me export as an .xml but to import i need a .csv. where do i get a .csv?
I have a sample xlsx here. You can export sheet 1 as csv for trying import.import_super_template.xlsx
how do i get something like this for my project?
Are you using the report browser? It has the ability to convert certain XML files to HTML or to TXT. And when a report is displayed, a right click in the report window will offer a menu containing export or display as other formats. Some steps even offer some options as part of the process.
And, it uses XSL Transformation (XSLT) language to accomplish this, which means that they are very customizable, if you know or learn XSLT syntax.
