I'm trying to assign a super elevation to a corridor, but nothing happens. I begin by referencing the SE file into the corridor(active file), select the assign super elevation tool, select the SE then the corridor and reset to complete. The box pops up and I fill out/verify the points and stations are correct, then I select "ok". After selecting "ok" the assign super tool starts over without placing the SE. I have a total of 6 models, 3 of which I have been able to successfully place SE and 3 I haven't. Any ideas?
Yes
This is the issue i'm having. is there a way to re-assign an alignment to the superelevation section?
From what I know there is no way to reassign a superelevation section to the alignement, what I do is export the superelevation section by doing a report and then I create a new superelevation section, create the lanes and then re-import the values that were exported with the report. I have found that the CSV report that comes with openroads does not work for everyone. If it does not work for you it can bebecause of the separator use, by default it's a coma (,) but for me it needed to be this (;) a point coma.
how do i export the superelevation?
you do a report,
