I am switching from Civil 3D to OpenRoads for a project and I cannot figure out if there is a way to modify the output of what is given in the horizontal alignment curve table.
Currently the only information given for the curves is this:
I would like a similar table but with this information:
The above information is provided in the complete Horizontal Alignment Review but I'd have to shift through the entire review and then separate it into these columns. Can I just modify the curve data table to show the 2nd images' results?
If you know XML/XSL, you can modify one of the default XSL sheets.
They are found at the approximate location of: ProgramFiles/Bentley/OpenRoads Designer.../OpenRoads Designer/Default/Reports
I wish you tons of luck with this.... Most people I know basically just copy the info from various reports into excel, and then just import the excel table into the DGN.
You can try to copy this xsl file to C:\Program Files\Bentley\OpenRoads Designer CE 10.10\OpenRoadsDesigner\Default\Reports\CivilGeometry\ and try to report it again.
HorizontalAlignmentCurveDataTable_Details.xsl
Good luck.
jing jing (o'.'o)
Answer Verified By: Hank Schauer
This is perfect!
Jing Jing I like your xsl curve data table I was wondering do you have xsl format for one that shows degrees like this example.
if not how can I modify it so that is shows that portion
Hi Joseph, what is "DEGREE" standard for?
a sample geometry with the table may help to find out
