Hi everyone,
Could you please help to guide that how to change "base line" into "line string" in OpenRoads Designer?
I use the line tool in geometry to draw line and want to change it to line string in some situation, please help to solve this issue.
Thank you in advance.
I may use "Drop Element" and make Application Elements: ON
jing jing (o'.'o)
Hi Jing,
Thank you. I also used drop tool, but after dropping, this line can not be edited in MicroStation.
Tuan
OpenRoads Designer CE - 2021 Release 2
(Version 10.10.21.04)
Oh, It seems that you are exporting the drawing model to plain graphics.
You may try this
https://communities.bentley.com/products/rail_design/w/rail_design__wiki/53706/export-to-plain-graphics---no-reference
Create New Configuration; and restart OpenRoads Designer
Then Save the drawing model to new DGN with "options"
Select the drawing "model" to export
Thank you, Jing Jing,
But it's not match my issue.
In detail, I created geometry line and want to convert it to nomar line or line string.
So that it can easy edit/delete in MicroStation in case of I dont have OpenRoads.
Because the geometry line created by ORD, it can not be edited/deleted by MicroStation.
You should be able to "Remove Rule" in order to convert the geometry into a plain line string.
Hi Matt Murphy,
Thank you for your advice, but when I remove rule, the geometry line become the line as same as doing "drop element".
It is not different and not become line string or normal line.
This should do what you need:
communities.bentley.com/.../remove-civil-model
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
