Openroads Designer - Stripping Component not showing in Component Quantities Report
I am trying to use the stripping component to calculate some quantities for this marsh project that I am doing. I currently have the top option to follow the component and the bottom option to follow the surface. In the picture below, the highlighted shape is showing correctly of what I need, but it is not showing up in my component quantity report. Is there a way to correct this to make it show up as a separate quantity item?
Sorry if this has been asked already. Thank you.
