When inputting data from a text file into a new Field Book it is not showing the data points, but giving me a "DEFAULT" in red letters under the All Point Feature under the Field Book tab in Explorer. Has anyone else had this issue?
Red "DEFAULT" maybe due to NO feature definition nor incorrect workspace you selected in opening DGN. You can try to open the DGN with Training and Examples workspace.
I imported the text file by using "File Using Text Import Wizard" to make sure Northing, Easting and Elevation are correctly imported.
jing jing (o'.'o)
Thank you for the tip!
