Remove Individual Annotation Groups
I'm working in ORD 2021 R1. Wondering if there is any way to remove individual annotation groups from the cross sections? I originally annotated all drawing models with EAV and have ultimately decided I wanted to remove it. We can add individual annotation groups to all drawing models but I don't see a way to remove individual groups, only remove all groups at once. Does anyone have a workaround for this?
  • This is great, Mark. Thanks for this. It saves a huge amount of time, as now it takes just a couple seconds to run through 20 or so models. I made a few changes that I think I'll capture here:
    * I revised some variable names to make them more explicit as to their purpose.
    * I added declaration lines because I use Option Explicit.
    * I changed ShowMessage to MsgBox because VBA was telling me the function wasn't working, but I changed nothing else about those lines.
    * I added a loop to cycle through all of the user's initial selection set rather than just the first one. (This is a less important improvement because the alternative is that the user would simply run the script multiple times according to the selection set.)
    At the top I mentioned this thread's URL for reference.
    Sub deleteAnnoInAllModelsOfSameFile()
        'substantially identical to the script that Mark Shamoun offered here: _
            https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/228930/remove-individual-annotation-groups/709368 _
            but with some variable names changed and a loop introduced to cycle through all of the user's selection set instead of just the first element's group
        Dim oScanEnumerator As ElementEnumerator, eeInitialSelection As ElementEnumerator, ph As PropertyHandler
        Dim oGroupName As String, ph0 As PropertyHandler, oElement As Element, oSelected As Element, oModel As ModelReference
        Dim count_drawing_models As Long
        Dim oSearch As String, oNew As String
        Dim totModels As Long
        Dim count_within_Model As Long, count_total_deleted As Long, count_annotation_elements As Long
        Dim count_Model_affected As Long
        Dim oRun As Long
        If ActiveModelReference.Type = msdModelTypeDrawing Then
            For Each oModel In ActiveDesignFile.Models
                If oModel.Type = msdModelTypeDrawing Then
                    count_drawing_models = count_drawing_models + 1
                End If
            Next
            If ActiveModelReference.AnyElementsSelected = False Then
                CadInputQueue.SendCommand "beep"
                ShowMessage "ERROR - No elements selected", , msdMessageCenterPriorityError, True
                GoTo finish
            Else
                Set eeInitialSelection = ActiveModelReference.GetSelectedElements
                Do While eeInitialSelection.MoveNext
                   Set oSelected = eeInitialSelection.Current
                   If oSelected.ModelReference.IsAttachment = False And oSelected.ModelReference.Name = ActiveModelReference.Name Then
                       Set ph0 = CreatePropertyHandler(oSelected)
                       If ph0.SelectByAccessString("Groups[0].Description") = True Then
                           oSearch = InStr(ph0.GetDisplayString, "\")
                           oGroupName = Left(ph0.GetDisplayString, oSearch)
                           If ph0.GetDisplayString = "" Then
                               ShowMessage "ERROR - Selected element is not Civil Annotation", , msdMessageCenterPriorityError, True
                               GoTo finish
                           End If
                       Else
                           GoTo finish
                       End If
                   Else
                       ShowMessage "ERROR - Only elements in active model can be used for this tool", , msdMessageCenterPriorityError, True
                       GoTo finish
                   End If
                   ' Save current model name
                   'currMod = ActiveModelReference.Name
                   Dim oScanCriteria As New ElementScanCriteria
                   ' Cycle through models and delete matching annotation group elements
                           totModels = totModels + 1
                           count_within_Model = 0
                           oScanCriteria.IncludeOnlyVisible
                           oScanCriteria.ExcludeNonGraphical
                           Set oScanEnumerator = oModel.Scan(oScanCriteria)
                           oRun = 1
                           'oModel.Activate
                           ShowTempMessage msdStatusBarAreaMiddle, "Processing Drawing model " + CStr(totModels) + " of " + CStr(count_drawing_models) + "..."
                           Do While oScanEnumerator.MoveNext
                               Set oElement = oScanEnumerator.Current
                               count_total_deleted = count_total_deleted + 1
                               If oElement.IsGraphical = True And oElement.ModelReference.Name = oModel.Name And oElement.ModelReference.IsAttachment = False Then
                                   Set ph = CreatePropertyHandler(oElement)
                                   If ph.SelectByAccessString("Groups[0].Description") = True Then
                                       oSearch = ""
                                       oSearch = InStr(ph.GetDisplayString, "\")
                                       oNew = Left(ph.GetDisplayString, oSearch)
                                       If StrComp(oNew, oGroupName, vbBinaryCompare) = 0 Then
                                           oModel.RemoveElement oElement 'TODO: reactivate this
                                           count_annotation_elements = count_annotation_elements + 1
                                           count_within_Model = count_within_Model + 1 'TODO: should this be count_annotation_elements ?
                                       End If
                                   End If
                               End If
                           Loop
                           If count_within_Model > 0 Then
                               count_Model_affected = count_Model_affected + 1
                           End If
                       End If
                       Set oElement = Nothing
                       Set oModel = Nothing
                       Set oScanEnumerator = Nothing
                   Next
                   ' Return to original model
                   'ActiveDesignFile.Models(currMod).Activate
                   If count_annotation_elements > 0 Then
                       MsgBox CStr(count_annotation_elements) & " total annotation element(s)  deleted from " & CStr(count_Model_affected) & " Drawing models." _
                            & vbNewLine _
                            & vbNewLine & "Removed Annotation Group: " _
                            & vbNewLine & Left(ph0.GetDisplayString, oSearch - 1) _
                            , , msdMessageCenterPriorityInfo, True
                   Else
                       MsgBox "No associated Civil Annotation found in any Drawing models", , msdMessageCenterPriorityWarning, True
                   End If
                Loop 'eeInitialSelection.MoveNext
            End If
        Else
            ShowMessage "ERROR - Tool can only be run in a Drawing model", , msdMessageCenterPriorityError, True
        End If
        GoTo finish
    skip:
    finish:
        CommandState.StartDefaultCommand
        Exit Sub
    End Sub
  • Awesome Derek, looks good.
    I'm thinking of enhancing this to provide a dialog with a list of currently found Annotation Group instances instead of needing to pre-select an element from a group as another option. Hopefully will have that done in the not too distant future.
    Mark
    OpenRoads Designer 2022 R3 (10.12)  |  Microstation 2023  |  ProjectWise CE 3.4
  • Mark,
    This looks like a great solution.  I didn't find this on the OpenCivil Product Ideas site.  Have you thought about adding it there so perhaps it can be added to the product itself?  I'm certain it would get a lot of votes.
  • I submitted this to the Ideas page a week or two ago. Looks like it's still under review or maybe didn't go through yet. But I did get a confirmation email. I had also submitted Enhancement Request 977276 a few months ago.
    Matt
  • For now, I have to hard code the name of the annotation group. As I learn more VBA,
    I recommend a couple changes as alternatives that might help you in your VBA experience and the longevity of this script and future work.
    1. Instead of setting the value of oGroupName in line 24, move that line up to line 2 to make it more obvious and so make the sub more repurposable.
    2. Instead of setting the value of oGroupName at all within this sub, have the sub receive that value as an argument and rename the sub: Sub deleteAnnoByGroupName(oGroupName As String). As for using it, create a new sub that does nothing but call this sub with the desired group name: deleteAnnoByGroupName "Design Annotations\XS Edge of Pavement\"
