It keeps showing up this error. What might be the issue? I am trying to apply point control to the shoulder.
I guess the linear geometry you selected is created by the same corridor. So, its recursive solution. Try other geometry.
jing jing (o'.'o)
This could also be the result of a snap constraint being applied on the geometry to a corridor template geometry, in horizontal or vertical geometry.
Answer Verified By: GP
Thank You
Thank You , it works now
