I just downloaded ORD on a new computer with Windows 11 pro. ORD will not open on this computer. is anyone else using ORD on a Windows 11 pro platform?
Maybe check to see if your Bentley Connection Client is installed and signed in.
I run Windows 11 at home and 10 at work. So far, everything works. I did have to set my video driver to control how Ss10 runs.
Hi Andy
Please note that the current version of OpenRoads Designer is certified to work on Windows 8 and Windows 10
docs.bentley.com/.../GUID-64E3BD8B-A625-40D4-A60E-DEF9F85B60B8.html
You may test installation on Windows 11 but it's not supported.
Hey Andy,
It works ok. But notice it's not certified yet by Bently and that means that if you have heavy work on it and 3d work it might crash on you. I am sure Bently will certify it soon after they finish all their tests.
Link to my YouTube channel where I share the knowledge. Enjoy.
Microstation Update 17 is certified for Windows 11 and I expect this is the PowerPlatform for the next version of ORD apparently coming soon.
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation CE Update 17.2 | ProjectWise CE 3.4
