Which versions of AutoCAD applications are compatible with InRoads version 8.11.07.615?
Hi Mike
Go to File > Save as > choose DWG > click on Options
In Options, under General Tab you'll see the DWG versions that your InRoads can handle
You can also refer to this article:communities.bentley.com/.../which-microstation-version-supports-which-dwg-dxf-version-formats
jing jing (o'.'o)
The version of InRoads that worked on top of AutoCAD stopped after AutoCAD became a 64 bit application. I do not recall what the InRoads version that was, but I believe it may have been Ss2.
Chuck:
We used that version of InRoads over a decade ago with Autocad. I remember it being called InRoads SelectCAD, and it was also compatible with Sun Solaris (at least at one time). We have since moved on to MicroStation/ Inroads and then Connect series software/ OpenRoads/ OpenBridge.
Mark
