Using the perpendicular measure tool from alignment works fine before a PT, but does not work beyond a PT along my alignment. The command keeps going to the PT. Is this something that would cause problems down the road? The label with text favorite works fine. Thoughts?
Thanks, Dawn
ORD 2021 release 2
Control_G.dgn
We've seen this before. There is a the slightest of a gap between the end of curve and the beginning of the tangent.
Matt Eiben
Answer Verified By: Dawn Michel
yep, that was it. Thank you!
