When I create a complex terrain. It will show both terrains in cross sections. Is there a setting I need to change, or is there another prosses I need to do, to hide the unwanted terrain?
I don't know that you will find a better solution than using a different feature definition so that you can either turn off display that feature definition or turn off the level showing the terrains.
That helped, I changed the level and turn it to no-plot. I always forget about that feature.
I love no-plot levels. I don't need many of them, but there is always information that we need when drafting that doesn't need to make it into the plans. They are also good when the engineer says "take out the mailboxes because we aren't including those" but you KNOW the county is going to come back and ask for them...
MaryB
Another option- Export the complex terrain and import in new model in same terrain dgn file. Reference the new terrain model to cross section dgn.
