Does anyone know how to use a .dscript to change the properties of a table in ORD? For example, in our dscript, we have the below code to determine the line thickness when plotting based on the weight of the line.
if (weight .eq. 0) then thickness = .008else if (weight .eq. 1) then thickness = .010
However, when I plot a table, it is not following this. I suspect this is because the borders in the table are part of the table element itself, and not it's own thing like a line would be. How do I tell the dscript to look for the weight of the border, or other properties of the table?
