Are there any good training videos on as to where it shows how to set up the point control on making templates (specifically the end conditions) as to where it ties to the existing pavement from the topo file given?
I would like to set up my templates using ORD (open roads designer) for the end conditions to tie into the existing pavement on the topo file.
  • I figured it out through training thanks
    In order to tie existing pavement to corridor
    Corridor > Edits > create point control > add start and end station > click on the corridor point you'd like to control > click the point you'd like to tie into
    Video on where it goes into more detail via Bentley Training as mentioned from commenters:
    QuickStart for Corridor Modeling - Road
    Modify the Corridor
    Answer Verified By: Christina Go
