in ORD 2021 R1 Readme Optimized printing/plotting to increase performance by 5x was announced.
We haven't noticed the performance improvement in 2021 R1 / R2 using provided pdf.pltcfg.
Has anyone experienced the performance improvement? Is there any specific setting or configuration variable required?
Mariusz
I think there are a few printing improvement variables I have seen.
MS_PLT_MAX_WORKER_TASKS = 2000CIVIL_ENABLE_QUICK_PRINTSERVER = 1
Hi Mariusz,
They fixed Print Organizer in 2021 R1, but broke it again in 2021 R2. I have 2 unanswered tickets for this. If you use Print Organizer just use the latest Microstation - it doesn't have errors and is much faster than in ORD.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Thanks svancleave for sharing!
Would you have any technical information about these variables? I haven't managed to find any description.
OpenRoads Designer 2022 R1
Hi Mark,
Thanks for the tip. We have experienced issues with Print Organizer in ORD 2020R3. We will try the MicroStation workaround.
I could not find any tech info and have only seen them is other published workspaces. I guess they are a result of a SR submitted
