We are getting more and more civil labels setup, but one issue that we are getting is related to the justification of the label. The label is set to use a dimension style ("Engr Circle"). When the civil label is placed, it lacks the dynamic justification and the leader will not switch to the other side, no matter how far I drag it over. After I place the label, it behaves the same way. As a check, I placed a normal note using that same dimesntion style and it performed fine. Any ideas why this isn't being formatted correctly? A couple screen captures are attached as an aid. (The first image is of the resulting civil label and of the standard label, the next is a capture of the dimension style settings, and the last is verification that the civil label is using the Engr Circle style)
ORD 10.10.01.03
Thanks!
Shawn,
I noticed the same behavior if I took out the Line frame. Then I recalled that our developing partner mentioned that he didn't have an issue with the label. That caused me to think about the version I was on (2021 R 1). I then updated to 2021 R 2 and now everything works as expected, WITH the Line frame! So it looks like it was an issue in early releases, but all is well now. Thanks for the troubleshooting help, Shawn!
