Hello everyone,
I have a project with +50 sheets and I'm having a problem with levels display in my sheets.
Basically, some of the level that are turned ON in my model are turned OFF in the sheets, and vice versa.
Do you have any idea how to solve this issue?
Best regards.
I would check how you set the Levels within the models. Are they on View Display or Global Display? This help file discusses the difference: Level Display Dialog (bentley.com)
Controlling Levels in Sheets from a Composite Drawing. - MicroStation Wiki - MicroStation - Bentley Communities
Thank you for responding. I will check out these settings and see if I get the desired results.
Another setting to check for the reference attachments to your sheets could be "Display Overrides". If you set this to "Never", it helps to minimize level changes between the reference and the active file.
Also, it's possible that, if these are set up with Saved Views, those saved views may need to be updated to reflect the current state of your reference.
MaryB
How can I update Saved Views ?
I don't use them yet (we aren't on CONNECT) so I'm not certain. Hopefully someone here will be able to give you some direction.
