OpenRoads exception on closing
On closing OpenRoads Designer and OpenRail Designer, I receive the dialog box asking me to Abort, Retry, or Ignore and that an exception log has been filed.
Exception caught in source file e:\builds\cif10102104\Source\Cif\src\managed\ui\tools\PrimitiveCommand\PrimitiveCommand.cs at method OnModelMotionInternal
Exception : The instance is not persisted.
In Assembly : Bentley.CifNET.Objects.4.0
Stack Trace :
   at Bentley.CifNET.Objects.Engine.Instance.GetECInstanceFromProvider()
   at Bentley.CifNET.Objects.Engine.Instance.AddInstanceAsDeletedAndPerformCascadeDelete(InternalChangeSet changeSet, Boolean rootIsExplicitlyDeleted)
   at Bentley.CifNET.Objects.Engine.Instance.BuildChangeSet(InternalChangeSet changeSet, PersistDepth persistDepth)
   at Bentley.CifNET.Objects.Engine.ObjectSpace.PersistChanges(ObjectKeyInternal ecKey, PersistDepth persistDepth)
   at Bentley.CifNET.Objects.Engine.ObjectSpace.PersistChanges(Object obj, PersistDepth persistDepth)
   at Bentley.CifNET.Objects.Engine.ObjectSpace.Bentley.CifNET.Objects.IObjectTracker.PersistChanges(Object obj)
   at Bentley.CifNET.GeometryModel.Tool.GeometryCommand.ObjectSpaceHolder.PersistChanges(Object obj)
   at Bentley.CifNET.GeometryModel.SnapRules.PointEntryCreator.RemoveSnapRuleAndSetCoordinates(DPoint3d pointCoordinates, IObjectTracker objectTracker, PointEntity2d pointEntity)
   at Bentley.CifNET.GeometryModel.SnapRules.PointEntryCreator.SetPointSnapInternal(DPoint3d pointCoordinates, SnapDescriptor snapDescriptor, IObjectTracker objectTracker, PointEntity2d pointEntity, Boolean checkCircularDependency, Boolean addSnapRule)
   at Bentley.CifNET.GeometryModel.SnapRules.DistanceAlongEntryCreator.SetDistanceAlongEntry(GeometricModel targetModel, LinearEntity baseElement, DPoint3d coordinates, SnapDescriptor snapDiscriptor, IObjectTracker objectSpace, LinearEntity targetEntity, DistanceAlongEntry distanceAlongEntry)
   at Bentley.CifNET.GeometryModel.Tool.GeometryCommand.DistanceAlongEntryDescriptor.Calculate(DPoint3d coordinates, SnapDescriptor snapDiscriptor, IObjectSpace objectSpace)
   at Bentley.CifNET.GeometryModel.Tool.GeometryCommand.DistanceAlongEntryState.DoGetCursorValue(IButtonEvent buttonEvent, Double currentValue, Boolean valueLocked)
   at Bentley.CifNET.UI.Tools.ParameterEntryState`2.InternalPrimitiveParameterState.GetCursorValue(IButtonEvent buttonEvent, Object currentValue, Boolean valueLocked)
   at Bentley.CifNET.UI.Tools.CursorPrompt.CustomParameterDialogDefinition.OnModelMotion(IButtonEvent buttonEvent)
   at Bentley.CifNET.UI.Tools.CursorPrompt.ParameterPromptManager.Bentley.CifNET.UI.Tools.ICommandParameterPrompter.OnDynamics(IButtonEvent buttonEvent)
   at Bentley.CifNET.UI.Tools.ParameterState.OnModelMotion(IButtonEvent buttonEvent)
   at Bentley.CifNET.UI.Tools.PrimitiveCommand.<>c__DisplayClass99_0.<OnModelMotionInternal>b__0()
   at Bentley.CifNET.UI.Tools.PrimitiveCommand.ManagedBooleanCallBack(Func`1 method, Boolean exitCommandAndCleanupCaches, Boolean retValue, String message, String memberName, String sourceFilePath, Int32 sourceLineNumber)
I checked Task Manager and the process OpenRoadsDesigner.exe never closes even if I select Abort in the dialog box.  This happens no matter what file I choose to open.  No customization has been done.  I have done the typical restart machine, reinstall with Admin privileges, etc.
Any help is appreciated.
Windows 10
OpenRoads Designer 10.10.21.004
  • Update: After several attempts of going thru several client custom workspaces I could not repeat the issue on a test machine but the issue continued to occur on machines where an automated uninstall of 10.10 R1 and install of 10.10 R2 was performed.  The issue did not happen on a few machines where I manually uninstalled 10.10 R1, deleted install directories and registry items, and then installed 10.10 R2.  I also re-imaged a computer and installed 10.10 R2; the issue has not surfaced for a week on that particular machine.  I am leaning toward some sort of .NET configuration issue on the computer or something did not get cleaned up properly after an automated uninstall.
