3D shapefile linestrings imported with modelbuilder
When importing 3D shapefile linestrings into my utility model using modelbuilder - ORD does not take into account the element elevations at each bend. I have a 3D linestring within my shapefile representing a ventilation conduit. This conduit has several vertices between the start and stop nodes. When I import that data using modelbuilder, modelbuilder is smart enough to add bends to the conduit, but the 3D element elevations are not coming through. They are simply being assigned an elevation linearly from the start and stop nodes.
Is there a way to have modelbuilder recognize the 3D vertex elevations between the start and stop nodes?
Any help is greatly appreciated!
Thanks!
