SS10 and GEOPAK field reopen problems.
Hi
I'm working SS10 and GEOPAk, but I'm having some trouble with the files after is created.
Some times after few days I'm tiring to opened the field but say "Field can't be open" and I loss everting that I did.
Some one know what is happen with this or why a have that message?
Typical window comment after crash
Porwer GEOPAK has detected a problem and logged it to
C:\User\name\AppData\Local\Temp\Bentley\PowerGEOPAK\8.11\XeG1V46hzkos_NZaNmnEsQ\exception.log
Thank you.
  • I have seen this...
    The only "fix" I know for it is a workaround and it depends on whether you can still attach the bad file as a reference. If so, you can create a new clean file from your seed, reference in the bad file, select everything and copy it into your new file. You could also select the reference and "Merge to Master", but straight up copying seems to work better. A file may have a corrupt bit of data, and copying the elements into a new file may save your work while leaving the corruption behind.
    I see this most often when running Geopak over ProjectWise, but I have seen it happen other times. While I don't know the cause, It seems to me the SS10 (which is based on SS4) just isn't as stable as SS2 and earlier versions. I've never been able to track down anything specific that causes it - it seems totally random.
    The other workaround is to keep a backup of your file on hand, and refresh it frequently.
    There is no way to repair a corrupted file.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • Thank you some much, this is a good alternative to restore the corrupts field.
Reply Children
