Hey,
I'm trying to use the Thematic Display: Aquaplaning (with Slope % enabled) to show a visual analysis of cross slopes. The settings are like in the image below. I basically want all slopes >1% to show blue and slopes <1% red
However, in the 3D view it shows slopes larger than 1% as blue which should be red. Image:
Whenever I change the settings from 0% - 1% = blue, to 0% - 0,5% = blue. The 3D view shows the slopes to a maximum of 1% (see image).
Is this a bug, or is there a setting to make the display style a bit more accurate? [Corridor interval is set to 0,25m]
Kind regards,
Beep boop to the top, anybody have anything. I've pretty much looked into every setting, but perhaps I missed something?
I'm also having a problem regarding the Thematic Display Styles: Slope. It seemed to me as the same problem, so that's why I'm posting it in this thread.
The terrain model is generated from lines with only a constant elevation (see view 1). So there's only a difference in hight between the lines in one direction. However, the thematic display style creates diagonal lines.
I would like to get an overview of the slope between the lines in perpendicular direction.
I'm also curious to know if this is a setting, or a known bug of some sort.
Thanks in advance,
10.10 Release 2, I don't know if I tested it with 10.11 Release 1 aswell. I heard some changes were made to thematic displays?
What version of ORD are you guys running
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
There is an issue with Thematic display with Terrains in versions older than 2022 Release 1 (that use older versions of Microstation). There are some workarounds on some older posts on the same topic. Not specifically this issue, but likely the same thing.
