I have a situation where my file has a nested reference. My file is being used by another discipline. The problem is the nested reference in my file is not showing up.
I am using Power GEOPak SS10, v. 09.11.09.918 and ProjectWise Explorer Connect v. 10.00.03.434. I have tried setting my reference to "Live Nesting" but that does nothing. The referenced file was rotated and moved, but that should have no bearing on whether is shows up or not.
And a review set had to go out today so I'm hoping to at least get the file to show up!
Thanks!
is it showing in the list of references in the reference dialog ? is it showing in red ?
Timothy Hickman
Main: 877 627 3772|
My file shows up in the list fine, but my file contains a (nested) reference file which needs to show up as well. That doesn't show up on the reference list, nor does it show up in Level Manager as a sub to my file, as I think it should.
if the reference file contains a reference itself then enabling the nesting and setting it to 1 should allow you to see the nested file.
Try doing an exchange from the reference dialog. It should put you in the referenced file. Now look at the reference dialog, is there a reference file attached ?
I did so (although I may have missed the "
Tim Hickman said:enabling the nesting and setting it to 1
part, I was able to exchange into the referenced file. The Reference Manager says this:
sorry.... That referenced file is the nested one which is not showing in the other file.
