I have a situation where my file has a nested reference. My file is being used by another discipline. The problem is the nested reference in my file is not showing up.
I am using Power GEOPak SS10, v. 09.11.09.918 and ProjectWise Explorer Connect v. 10.00.03.434. I have tried setting my reference to "Live Nesting" but that does nothing. The referenced file was rotated and moved, but that should have no bearing on whether is shows up or not.
And a review set had to go out today so I'm hoping to at least get the file to show up!
Thanks!
FYI..
I just made a new file and referenced the nested file into that, and then referenced the new file into the target file Nested file still does not show.
Sometimes things clear up when you make a new file....sometimes not.
You could close ProjectWise Explorer and rename/delete the cache folder on the c:\ drive. Re-open ProjectWise and let it rebuild the cache and see if the file is still missing.
can you send a screen shot of the reference dialog for the main file where you are not seeing the nested reference ?
Timothy Hickman
Main: 877 627 3772|
Yup! I will get that on here first thing in the morning.
Thank you, good sir!
Try disabling the "Ignore Attachment when Live Nesting" setting.
