When using a tool that loads a VBA macro such as the tool below.
A Run-Time error pops up indicating that ORD can not open the file. The Macros are in the 'standards\macros' folder and the config variables have the correct file path to load them.
Hi Zach,
I bet it can't locate a cell library it is trying to open in the background as part of the macro processing. Check all the cell libraries are where they should be by default and see if it still happens.
Mark
Answer Verified By: Zach Walgers
Thank you Mark, I changed the name of a cell dgnlib and it was trying to search for that old file name.
