Has anyone tried using civil accudraw with direction/direction? I've setup the direction/direction button and I'm trying to store a point at the intersection of two bearings. I have the 4 surveyed points shown below that I want to use to define the two different bearings but I can't seem to make it work. Any help would be greatly appreciated.
Once in the command and first line is started (start line at NE point, then tentative to the SW point and hit enter to lock the first bearing, then right-click to get out of tentative snap), select "O" for set origin shortcut, it will allow you to select the beginning of the secondary bearing. Then lock that second bearing. Roughly pictured below.
OpenRoads Designer Accredited
colliersengineering.com
The problem we're having is that if we right mouse click, it kicks us out of the command. If we hit the "O" it just starts typing O's as shown in the screen capture.
I've noticed several of these ORD entry fields can do this. Sometimes how/when that dialog gains focus is key to enabling the origin shortcut. The origin command can also be added to the civil accudraw toolbox.
Thanks. I ended up submitting this as a service request.
