Hi All- Looking for some guidance on how I can cut consistent cross sections using a Referenced Named Boundary file I created. I followed this video exactly, with the only difference being the video is cutting plan/prof and not cross sections. Any advice would be appreciated.
https://www.youtube.com/watch?v=VgylsdJayt4
Use the same method...just click on cross section instead of plan & profile in named boundaries
Believe I found the answer for referencing in cross section named boundaries.... within the 2D model, import the reference, live nest it, activate your 3D model and take the "Civil Point Analysis Tool" and within the 3D Model view, touch on the one of the referenced named boundaries from your reference, this seems to activate the Named Boundary Group for use!
