I'm attempting to create an intuitive template that seeks the existing terrain model but also interacts with a horizontal geometry, in this instance a Right of Way, so that the corridor will use a different end condition based on the distance of the horizontal distance of the Right of Way to my track formation.
There's a video on YouTube of exactly what I want to achieve (Tech Talk: Intelligent Side Slopes - Effectively Modeling End Conditions in OpenRoads Designer) however i'm having trouble on the step where I need to incorporate the second geometry into my corridor.
I've added the horizontal geometry as a corridor reference but this reference isn't available to select when I open the define target aliasing window to define another target for the template to seek.
Any Ideas?
It looks like you do not have another target type defined in your end condition. The end condition that seeks the horizontal ROW feature should have a "Linear XY" target type.
Marc
Answer Verified By: Kevin Man
This was exactly it, I didn't change the target type
Thanks!
Kevin
