I believe I've had this issue before but got it again today. Sometimes when exporting to DWG some geometry doesn't get exported. In this case it's a complex made up of a number of intervals, lines, arcs etc.
I've tried a Compress and can't see any issues in the model.
Anyone else have similar issues sometimes? Anything I should look for? any particular settings which might help?
Ken
The difference is that as it merges the data on export, it strips all civil data (the same way a merge to master would with ORD elements). It also only includes the levels of merged elements giving you a cleaner export on terms of layering.
Mark
Answer Verified By: Ken Bagnall
