*EDIT: I found that these are actually Graphic Manipulators, is it possible to convert these to actual annotations?
Does anybody know if it is possible to export the slope wedges (see figure) from a Superelevation section to a DWG file. Viewing the wedges in ORD is great, but we need to be able to create XREFs for our Civil3d folks. I don't really care about the Superelevation fill (colors), the wedges are what we need in a DWG format.
Is there a hidden setting somewhere or does ORD not have the function readily available. Whenever I export the file to .DWG, it won't bring the wedges with it.
I'm using 10.10.21.4
Kind regards,
I think that is kind of at the heart of the issue here. I suspect they are stored as "properties" of the Superelevation Lane object and are rendered "on the fly" as manipulators. I have only poked around in the Text Favorites a little, but when I attempted to generate anything using the Superelevation Propeties, the software crashes.
www.envisioncad.com
ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33Power GEOPAK / Power InRoads - 08.11.09.918Civil 3D - 2021 / 2022
I'll take another look and see if I can find something. Thank you for your help!
see here for a workaround/answer: ORD - Annotate superelevation in plan? - OpenRoads | OpenSite Forum - OpenRoads | OpenSite - Bentley Communities
