Hi everyone
When I open Openroads, I see the persist snap is always turned on. I concern the "persist snap" will affect any object I draw.
Therefore, I always turn it off after opening software, that's annoying.
Could you please let me know which type of object that "persist snap" is working and affecting accordingly?
Thank you so much.
I'm sure I've seen ORD suggest other types of objects create a persistent snap with it on, the only example I can think of off top of my head is key stations in corridors. They show the little snap symbol as usual but obviously don't update like they should. I can only assume this is an error and try to remember to avoid it as I do wonder if it would affect the stability of the model.
