How can identified ORD vs SS10 dgn file?
I'm working on between survey and roadway data at the same time. But the survey team is using SS10 with GP and the roadway using the ORD.
Some time I have the files for both at the same location and I want to know if a easy way to identified what type of dgn before to open it (SS10 or ORD)?
Thank you.
