I am using open Road designer 2021 Release2, Is some one tell me the exact process of exporting DGN file to DWG File ?
I tried to export the DGN File to DWG File but all the layers not exported properly. Kindly Help
Hello Neeraj,
Can you please upload your dgn file in the below link so that I can test it at my end and provide you possible solution ?
https://bentley.sharefile.com/r-r23cffdf6aa9c4254ab8ff3f02388fa79
Meanwhile, May I request you to please go through the video demonstration as shown in the below link ?
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/37342/video-export-a-dgn-file-with-geo-coordinates-to-dwg
Thank You,
Purva Lakde
Mark Shamoun posted this thread about their ORD -> DWG export process: https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/169182/ord-dwg-export-workflows
Maybe something in there could be helpful.
MaryB
I have uploaded the file pls export the profile Drawing ... which is not correctly exported....
I watched this video before with export Cross Section to DWG (but not in English). It maybe a reference for you.
They mentioned: 1. Version of DWG; 2. "Merge" of reference and 3. select drawing models to export.
Hope it helps.
jing jing (o'.'o)
I exactly Follow the steps as shown in videos but still not found desired output...
