Hi everyone,
Please help me to solve this issue:
When I create corridor with 1m interval, the corridor is not matching with turn lane at start or corner or turn lane as picture below:
How can I match the corridor interval and turn lane corner?
Thank you so much
Parker, how about adding a key station to your corridor at both corner points?
Another option if you are defining the turn lane taper with point controls would be to use a Corridor Feature Definition with "External Control Points" set to "True".
Hope that helps.
Steve
www.envisioncad.com
ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33Power GEOPAK / Power InRoads - 08.11.09.918Civil 3D - 2021 / 2022
Answer Verified By: Tuan
Hi Steven Vander Giessen
When I add key station, I found that the corridor was separated as red circle in attached picture.
Coud you please have a look to my file: Corridor.dgn
Tuan
OpenRoads Designer CE - 2021 Release 2
(Version 10.10.21.04)
Hi Steven Litzau
Thank you so much.
Following your instruction, I fixed my issue.
Glad that worked for you!
