Is there a way in OpenRoads to export drainage model to IFC?
I know there is a way to export the terrain model to IFC (as shown below), but it seems the drainage model is missing in the exportation.
Thank you!
Are all the properties of a drainage element defined in OpenRoads can be exported into IFC?
Look like yes. The drainage properties are also exported to IFC.
jing jing (o'.'o)
Unfortunately, only the featured civil elements are included in the IFC exporting. I have tested to convert solids to MicroStation meshes and then I have applied a Feature Definition, It´s a very slow method but it works, another way is to export the 3D model from OpenBuidinds.
iTwin stopped working. Are there Updates in ORD? Is it now possible to export drainage and utilities directly from ORD?
@ OpenCivil Ideas portal. Link DU: IFC export | Bentley OpenCivil Ideas Portal (aha.io)
