Can't change FD on Terrain model even in the actually designfile.
I have recently updated my ORD to 2021 R2 update 10.10.21.04.
Earlier on, I believe I could create a terrain by element and go to the explorer to change FD to another one?
Like this:
and then go to properties and change FD but now it is locked!
OR - as fare as I recall - I could go to the 2d model and get the properties here and then change the FD but now it is reading it as if it was in a referencefile and I can only override with an ET:
But then when I go to my 3d model, catch the actually terrain and - only from here - change the FD:
I think I would like to be able to do the same through the Explorer if many terrains are present for example
But does this work as designed and why? :-)
Signe
