Open roads Crashes/Closes on attaching a cad file. Kindly help
If OpenRoads can open that CADD file, i will convert it as DGN and the reference it.
jing jing (o'.'o)
I knw that but open roads isn't working after importing. It closes
What version of DWG is it?What version of ORD are you running?
If you can check, does the DWG open fine in AutoCAD?
MaryB
My workstation includes the following software:
ORD 10.10.21.04
SS10 08.11.09.918
C3D 2022 13.4.2119.0 (State Kit)
Our IT department recently updated ORD to 10.10.21.04
When I opened an ORD survey file,
ORD would actually crash when trying to Xref a DWG file. (regardless of ACAD version)
I read in a Bentley thread, that adding an underscore to the end of this folder name may resolve the issue:
C:\Program Files\Autodesk\temp\Civil 3D 2022 Object Enabler
So – new folder name:
C:\Program Files\Autodesk\temp\Civil 3D 2022 Object Enabler_
Does resolve the issue in ORD.
But my version of SS10 has now lost it’s ability to Xref a DWG. (regardless of version)
I have tried every version from v.2000 through v.2018
Removing the underscore from the Object Enabler folder will also not work.
I did notice that our IT department has also updated to SS10 version 08.11.09.918
As a test, I found another user in our department with the following set up:
SS10 08.11.09.878
His machine has the same issue in ORD, which is resolved by adding the underscore.
But his version of SS10 can still read the DWG files, with or without the underscore.
At this point I am suspect that version 08.11.09.918 may have issues related to the ACAD Object Enabler.
Additional info…
We also have a user that has
But he’s only up to v.2020 on his C3D.
His SS10 is able to Xref DWG’s without issue.
New theory…
08.11.09.918 is not playing nice with AutoCad Object Enabler 2022
Hi Michael,I've experienced something similar except for me it is only some and not all DWG files.I too am running ORD 2021 R2 and Civil 3D 2022 with the object enabler installed.What I have found is that any DWG file which has any Civil 3d data in it, or has been created from a Civil 3d template, or has simply been opened and saved in Civil 3d is enough to trigger the issue for me.The only fix i've found that works is to open the offending file in Autocad or Civil 3d and type "EXPORTTOAUTOCAD". This creates a stripped down version of the file which doesn't contain any Civil3d object data, then I reference this file into ORD.
Answer Verified By: Atif Ahmed
