Dynamic Sections: has anyone run into using Section via Datapoint and getting the plan view elements in the cross section window? If so, were you able to get a fix?
So, instead of seeing the sliced graphics in the Section View (centered around structure elevations and zero offset) the view shows the model in top view centered around the northing and easting of the plan graphics.
Note: I'm doing this using a baseline rather a corridor - this is largely for drainage structure review rather than corridor review (adding corridor would be possible but a burden (multiple corridor phases along the baseline and it burdens an already heavy slow file)
Thanks!
-jeff
Hi Jeff, dynamic sections will show what is in the Default-3D model - is it possible that you don't have a 3D model created yet in the file you're in?
Note: "geometry dynamicsection deletedxsviews" does not help. 3D Model is indistinguishable from others where things work fine. I've stripped down my file from dozens of refs to just a terrain (that works elsewhere) and a drainage reference (I'm thinking it's something in the drainage).
from Bentley Support: Delete all View Groups except "Multi-Model Views". Delete any "unnecessary" [?!] models (not Default or Default-3D). Double-click on Default Model. Proceed.
Some success.
