Hi everyone,
I projected intersection point of road A into profile of road B for reference.
When I create the profile of road B with specific radius of curve, I found that the elevation of profile that is not matching elevation with intersection point.
If I drag point of curve in order to match elevation with intersection point, causing the change of radius which I don’t want happen.
Could you please let me know the efficient way to match elevation for the vertical curve to intersecting point? (keeping specific radius).
And, how to create vertical curve to match with intersecting point in elevation?
Thank you so much
----------------------------Parker
OpenRoads Designer CONNECT Edition - 2020 Release 3 - Version 10.14.04.04
