Hi everyone,
When drawing vertical curve with radius = 300m as picture below, I need to adjust the origin of curve into specific elevation (or intersection point).
I drag the origin of curve into the specific elevation (or intersection point), but the radius is also being changed automatically.
My question that is how to make the origin of curve matching with the specific elevation (or intersection point) while keeping the radius as I want (r=300m)?
Thank you for your help.
Parker
OpenRoads Designer CONNECT Edition - 2020 Release 3 - Version 10.14.04.04
If the entrance and exit grades are fixed and you have a circular vertical curve with a fixed radius then there is only one mathematical solution to create the curve tangential to the entrance and exit grades so the curve could not be adjusted without changing either the radius or the grades
Thank you so much, Paul.
Tuan
OpenRoads Designer CE - 2021 Release 2
(Version 10.10.21.04)
