Inroads select series 2 will annotate station to station in my cross section. How can I do that in OpenRoads Designer?
Attached is a pdf cross section sheet for OpenRoads Designer and Inroads SS2
PDFPDF
The fact that 80 users have viewed this post and no one had an answer is very telling...
It's not currently supported but will become available in an upcoming release later in the year via the addition of some new text favorites.
Answer Verified By: JDF
Thank you Paul. This will be a big help. Currently I have to label them manually and I can have 500 cross section sheets on a highway project.
As a workaround, we use specific naming of our drawing models, ie. "MC10 - STN 999" to accomplish this (for at least the start station of the sheet).
This can be put in the title block by inserting a text field using the drawing boundary in the sheet (by selecting the section marker). There is a property for drawing link name
Not exactly what you are after, but something that can help.
Mark
