Hi everyone,
When I create corridor and turn on 2 views plan/3D.
I am zooming a location in 3D view, could you please guide me how to switch to the same location in 2D plan?
I can switch quickly same location from 2D plan to 3D view by choose "2 views plan/3D" as picture below, but I don't know how to switch from 3D views to 2D plan with same location.
Please help.
Thank you so much.
Parker
OpenRoads Designer CONNECT Edition - 2020 Release 3 - Version 10.14.04.04
Tuan
OpenRoads Designer CE - 2021 Release 2
(Version 10.10.21.04)
I guess you will need to do a vba script, similar that opens 3D view that exhibits 2D - the one that you show on the printscreen.
to find location of a 3D element in 2D you can use Analyze Point tool, select linear object in 3D and a cross will be displayed in 2D.
Best,
Adam
OpenRoads Designer 2023 | OpenRail Designer 2023
Answer Verified By: Tuan
Hi Adam Wieczorek
Thank you so much with your instruction. Its great and useful.
Now, I believe that your instruction is the most efficient way I know.
