Displayset on ORD
Probably an easy question for some..
On Microstation/GEOPAK, I often used Create Display Set command on LevelDisplay to quickly isolate and single out levels that I want to specifically look it. On ORD, it doesn't activate or isolate that layer. What am I doing wrong? The model description shows [Displayset] but the view looks the exact same.
Parents Reply Children
