Hello everyone,
When creating profile drawing I uncheck Open Model, but the sheet model gets open anyways. And when I try to get back to the Default model it takes a lot of time, and sometimes it craches.
Has any of you faced this issue ?
For info, I'm using ORD 2021 R1.
Hi Yousef,
I believe this is the result of a few issues- the Open toggle doesn't work and the Sheet draw time is quite slow in 2021 R1. It shouldn't crash though.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Has this been solved in 2021 R2 ? and is there an option I can use to not create the sheet model?
