Have you noticed this in all your models or is it a particular model your working with? Typically I have found 8i to be better with graphics in general. If it is a specific dataset it would be good to take a look at it.
I have seen some data import slowly (not sure why). In one instance we enabled a 3GB switch which then allowed the data to process quickly, yet the same data on another machine processed fine without any switch.
Please send me the data when you get a chance
Mike.barkasi@bentley.com
Michael Barkasi
Application Engineer
Reality Modeling
Chris,
Are you mapping cells?
If so, see if you have any "Named Groups" in your design file. Delete them and then re-visualize.
Derricke
