How can a Microstation Terrain be given civil rules i.e. turned into a ORD Terrain? For context the Terrain has come from a STM.
I've tried to follow the official documentation i.e. Set Feature Definition, select Terrain category: https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/21738/use-scalable-terrain-models-in-openroads
But nothing happens, no errors etc., just says as a Terrain. Tried changing the Terrain resolution and extents but no difference. Also tried leaving it as no feature definition.
Any ideas?
Ok, it should work on 2022 R1.
I had issues in the past and had to use workaround : export MS Terrain ans LandXML and import LandXML, but again I worked on my last use cases, so you may give a try next time...
Vincent RAULT [Bentley]
I did do it on 2021 so you may be correct. I'm on 2022 now so will try it when it comes up again. Otherwise I'll give your workaround a try. Thanks.
